I’m waiting for delivery of my new vm167. I would realize a fader unit to drive, via the five analog inputs, my vb.net program that send commands to dmx units.
Can you please give me an example scheme using 5 sliders?
What’s the value of the sliders?
Did I need an external supply?
[quote]What’s the value of the sliders?[/quote]The input resistance of the VM167 is 30k. You should use 1k - 10k slider potentiometer to get good linearity.
[quote]Did I need an external supply?[/quote]No. You can use the +5V from the board.
Thank you very much for your speedy and precise answer!
Now I have another question:
I’m implementing my vb.net program with vm167 management.
There is a conflict between the vm167 mpusbapi.dll and the same distributed with dmx-510usb unit.
If I use one, don’t works vm167 functions and vice versa.
For now I bypassed the problem writing two applications communicating via tcp socket, but there is the way to merge the two dll?
I hope you well anderstood, because of my bad english.
I saw it, and I have win7… but I’m developing with no installed driver at all.
I don’t understand how can I solve the problem continuing to use the vm167.dll in declare functions.
Anyway, I wait for the card and then I will try with that driver.
