VM153EU use in Spain
I wish to buy some VM153EU units for use in Spain. Because Spain does not use the earth pin of the Schucko plug the Live & Neutral are not generally defined in Spanish sockets and often can be on the left on some sockets in a room and on the right on others - my question is “does this make problems for this device?”
Regards
Alister Bottomley
This is no problem
Just check your socket
You can choose between our main article nr VM153EU http://www.velleman.eu/distributor/products/view/?id=378398
or the VM153EUS ho has a “Schucko plug”
http://www.velleman.eu/distributor/products/view/?country=be&lang=nl&id=378966
