My VM153EU got wet and the R9 burned out and i can’t read its value anymore. What’s the correct value?
Thanks, Piet
Thanks, Piet
The resistor must be 220 ohm (normal 1/4W resistor).
It’s possible that also other components may be damaged…
[quote=“VEL456”]The resistor must be 220 ohm (normal 1/4W resistor).
It’s possible that also other components may be damaged…[/quote]
Thanks!, the only other component that was damaged was the fuse.
Regards, Piet
