Hello. I am from Germany and my english ist not so good, so i do my very best.
I have a question for the VM147 Module. The modul have a output. Can i take on this output a relais that switch (give a impuls on the Relais so the relais turn on an after 1sek off) when the number i have set in the VM147 for the endnummer? Where must i connect the relais, on wiche pins?
best regards and sorry for my english i hope you understand me.
Yes, no problem.
Pin4 of the connector is an “open-collector” output and can drive a miniature relay, contact this pin to the coil connection, the other coil connection goes to your power supply (ex. +12V if you are using a 12V relay)
