Hi there
This post is for JAVA-Programmers.
I found an easy solution to access the VM140/K8061 card with JAVA. It is easy to do the same with other cards.
You have to download the JNative-Library from jnative.free.fr for accessing DLL’s from Java-Code dynamically.
This is still not alway easy to use, mainly because of passing of parameteres to the DLL. So I wrote a wrapper-class (VM140.java). For testing I use a JUnit-Java-Test-case (VM140Test.java). Both ist tested with JAVA6 running on a VISTA-32-Bit-PC.
Hope it helps some of the folks.
randb.
package test;
import org.xvolks.jnative.JNative;
import org.xvolks.jnative.Type;
import org.xvolks.jnative.exceptions.NativeException;
import org.xvolks.jnative.pointers.Pointer;
import org.xvolks.jnative.pointers.memory.MemoryBlockFactory;
* Hält einiges zentrales und ist die Facade zur USB-Schnittstellenkarte VM140
* @author randb
* DEMO-Version für FORUM
* 08.04.2010
public class VM140 {
private static final short INVALID_CARDADRESS = -1;
private static final String VM140DLL_NAME = "K8061.dll";
private static final int VM140_IMPULSE_DURATION = 500; // in mSecs
private short mCardAdress = INVALID_CARDADRESS;
public VM140() {
super();
//@deprecated
public static JNative getDLLObject(String functionName) throws NativeException {
return new JNative(VM140DLL_NAME, functionName);
private String getParam(short param) {
return "" + param;
public boolean hasCardNumber() {
return (mCardAdress != INVALID_CARDADRESS);
private JNative createDLLObject(String pCommandName) throws Exception {
System.out.println("**\\** createDLLObject(); pCommandName=" + pCommandName);
JNative dllObject = null;
try {
dllObject = new JNative(VM140DLL_NAME, pCommandName);
} catch (NativeException e) {
throw new Exception("VM140 failed getting command=" + pCommandName, e);
return dllObject;
private Pointer createPointer(int pSizeInBytes) throws Exception {
try {
return new Pointer(MemoryBlockFactory.createMemoryBlock(pSizeInBytes));
throw new Exception("VM140 failed creating pointer of size=" + pSizeInBytes, e);
private String pointerToString(Pointer pointer) throws NativeException {
int pointerSize = pointer.getSize();
byte[] validBytes = new byte[pointerSize / 4];
byte charByte = 0;
for (int i=0; i<validBytes.length; i++) {
charByte = pointer.getAsByte(4*i);
validBytes[i] = charByte;
return new String(validBytes);
private boolean checkBoolean(String retValue) {
return "1".equalsIgnoreCase(retValue);
private void sleep() {
try {
Thread.sleep(VM140_IMPULSE_DURATION);
} catch (InterruptedException e) {
System.out.println("sleeping was interrupted " + e.getMessage());
* Oeffnet eine Verbindung zum VM140
* Speichert die Adresse in der Instanz-Var mCardAdress
* @return boolean --> vernünftige Karten-Adresse gefunden
public boolean openDevice() throws Exception {
JNative dllObject = createDLLObject("OpenDevice");
try {
dllObject.setRetVal(Type.INT);
dllObject.invoke();
String returnValue = dllObject.getRetVal();
mCardAdress = (new Integer(returnValue)).shortValue();
System.out.println("**\\** end of openDevice(); returnValue=" + returnValue + " mCardAdress=" + mCardAdress);
} catch (Exception e) {
throw new Exception("testing connection to VM140 failed", e);
return hasCardNumber();
public void closeDevices() throws Exception {
JNative dllObject = createDLLObject("CloseDevices");
try {
dllObject.invoke();
System.out.println("**\\** end of closeDevices();");
throw new Exception("closing devices of VM140 failed", e);
} finally {
public boolean isConnected() throws Exception {
boolean connected = false;
JNative dllObject = createDLLObject("Connected");
try {
dllObject.setParameter(1, Type.INT, getParam(mCardAdress));
dllObject.invoke();
connected = checkBoolean(returnValue);
System.out.println("**\\** end of isConnected(); returnValue=" + returnValue + " connected=" + connected);
return connected;
public boolean isPowerGood() throws Exception {
boolean powerGood = false;
JNative dllObject = createDLLObject("PowerGood");
try {
dllObject.invoke();
powerGood = checkBoolean(returnValue);
System.out.println("**\\** end of isPowerGood(); returnValue=" + returnValue + " powerGood=" + powerGood);
throw new Exception("testing power of VM140 failed", e);
return powerGood;
* Holt den Versionsstring
* @return Versionsstring, NULL oder leerer String "" falls nicht ok
* @throws Exception
public String readVersion() throws Exception {
String version = null;
JNative dllObject = createDLLObject("ReadVersion");
Pointer bufferPointer = null;
try {
dllObject.setParameter(0, Type.INT, getParam(mCardAdress));
bufferPointer = createPointer(50 * 4); // 50 long integers
dllObject.setParameter(1, bufferPointer.getPointer());
dllObject.invoke();
version = pointerToString(bufferPointer);
System.out.println("**\\** end of readVersion(); version=" + version);
throw new Exception("reading version of VM140 failed", e);
} finally {
try {
bufferPointer.dispose();
} catch (Throwable ignore) {
System.out.println("failed disposing pointer " + ignore.getMessage());
return version;
public void clearAllDigital() throws Exception {
JNative dllObject = createDLLObject("ClearAllDigital");
try {
dllObject.invoke();
System.out.println("**\\** end of clearAllDigital()");
throw new Exception("clearing all digital outputs of VM140 failed", e);
public void setDigital(int channel) throws Exception {
short channelShort = new Integer(channel).shortValue();
JNative dllObject = createDLLObject("SetDigitalChannel");
try {
dllObject.setParameter(1, Type.INT, getParam(channelShort));
dllObject.invoke();
System.out.println("**\\** end of setDigital(); channel=" + channel);
throw new Exception("setting digital output of VM140 failed for channel =" + channel, e);
public void clearDigital(int channel) throws Exception {
JNative dllObject = createDLLObject("ClearDigitalChannel");
try {
dllObject.invoke();
System.out.println("**\\** end of clearDigital(); channel=" + channel);
throw new Exception("clearing digital output of VM140 failed for channel =" + channel, e);
* Gibt einen Impuls auf den digitalen Kanal, d.h. aktiviert und deaktiviert ihn wieder
* @param channel
* @throws Exception
public void impulseDigital(int channel) throws Exception {
System.out.println("**\\** impulseDigital(); channel=" + channel);
try {
setDigital(channel);
sleep();
} catch (Exception ignore) {
System.out.println("setting digital chennel failed");
} finally {
try {
clearDigital(channel);
System.out.println("clearing digital output failed " + ignore.getMessage());
clearAllDigital();
package test;
//import ch.randb.vm140.VM140;
import junit.framework.TestCase;
public class VM140Test extends TestCase {
private static VM140 vm140 = new VM140();
public void test01() {
try {
System.out.println("VM140Test > openDevice");
assertTrue(vm140.openDevice());
} catch (Exception ex) {
ex.printStackTrace();
assertTrue(false);
public void test02() {
try {
System.out.println("VM140Test > isConnected");
assertTrue(vm140.isConnected());
assertTrue(false);
public void test03() {
try {
System.out.println("VM140Test > isPowerGood");
assertTrue(vm140.isPowerGood());
assertTrue(false);
public void test04() {
try {
System.out.println("VM140Test > readVersion");
String version = vm140.readVersion();
assertTrue(version.length() > 0);
assertTrue(false);
public void test05() {
try {
System.out.println("VM140Test > setDigital(1)");
vm140.setDigital(1);
assertTrue(vm140.hasCardNumber());
assertTrue(false);
public void test06() {
try {
System.out.println("VM140Test > clearDigital(1)");
vm140.clearDigital(1);
assertTrue(false);
public void test07() {
try {
System.out.println("VM140Test > impulseDigital(2)");
vm140.impulseDigital(2);
assertTrue(false);
public void test08() {
try {
System.out.println("VM140Test > clearAllDigital");
vm140.clearAllDigital();
assertTrue(false);
public void test99() {
try {
System.out.println("VM140Test > closeDevices");
vm140.closeDevices();
assertTrue(! vm140.hasCardNumber());
assertTrue(false);
