VM140 analog output
hello,
i have a VM140 board. it is working as it should, except for the analog outputs. i need them to be 0 to 10V, but they only go up to about 9.5V. this is a problem for my application. do you know what could be done to adjust the maximum voltage?
thanks
stephan
You can increase the output voltage by reducing the value of the resistors R11, R12, R22, R23, R28, R29, R35 and R36.
Connecting 100k resistor in parallel of the resistor will increase the output voltage about 5%.
thanks a lot. i will try this as soon as possible.
stephan
finally i was able to try it out. i added 100k resistors to the outputs i needed and they are all now slightly over 10 volts, which is exactly what i wanted. thanks again for the solution
stephan
