VM137 sensor
Hello, we want to change sensor ,temp. range : 5 to 30°C and we need an other range.
Can you help me to find a product compatible.
I 'm using 170 kits for a project.
Regards
Basically, you need a 10K NTC with a different range.
Depending on the range, you will also need to change some resistors on the board.
The board indicates which resistors to change. Sorry, no values, please experiment.
Sorry, we do not carry such an item.
You might want to check with DigiKey, Mouser, Farnell, etc…
