Vm132
We are stepping into your temperature prints VM132 because these
would have more features.
We report this to an analog input of a PLC with which we
processing values.
The story is so both with me and with our programmer
confusion has come about which voltage / current from the prints
comes.
there are described 0-10 V and 0-20 mA (both on the package)
But what is the standard without resistance?
I assume that the resistances which are included, are purely just
the signal to convert from mA to 0-10v or vice versa ??
Or do something else, the resistors also in the process of the print?
The following questions:
  • Suppose we have a supply voltage of 10Vdc works print than
    also?
    what would be the difference in the temperature?
  • Yesterday I had joined him on the supply voltage of 10Vdc and
    there 8Vdc came out as output, this is the correct voltage?
  • There are also temperature prints (same size) with a
    supply voltage of 24Vdc? and an analog output.
