I’m looking for a slow on-slow off dimmer (15 min) to control PAR38 LED lamps 230V. Is this unit suited? Can the time being set to 15min?
Or do you have another solution?
Thanks,
André Jodogne
Thanks,
André Jodogne
This dimmer doesn’t have a “SLOW ON/OFF” function.
First be sure that your LED lamps are dimmable !
Most likely, if the incandescent lamps are fed from the 230VAC, without transformer, they are dimmable.
K8028 is a slow on/off dimmer that might suit your needs.
http://www.velleman.eu/distributor/products/view/?id=343638
