I have the vm130 kit. I want to extend this module.
Are the (tx433) sender an receiver (rx433) compatible with each other?
If I send something with the vm130, would it be detected/decoded with the rx433.
Thanks for the answer.
The VM130 and the TX433 will interfere with each other.
You could try with another sending frequency
That doesn’t answer my question and is not entirely true.
I have a post with remote control, works perfect. no inerference…
I uses remotely (a cheap) control for several standing lamps. no interference
I only want to know wich modulatie the VM13 works. Then I can extend my automation with Velleman.
Otherwise I will look for an other sollution.
http://www.gloria-atletiek.nl/wp-content/uploads/2015/12/Happy-New-Year-2016-Wallapapers.jpg
the vm130 use AM
