I am aware it says 9-13v but can I use a lead acid battery which could go up to 14.5v to power the VM130? I have checked the specs of the 5v regulator and the relays and they seem to be good for more than 14.5v.
Not much activity on this forum.
In the specs (below) it states the receiver can use 10 to 15Vdc
[ul]
[li]receiver:
[list]
[][color=#FF0000]power supply: 9 to 13Vac or 10 to 15Vdc[/color]
[/li][li]consumption : 130mA max. / 20mA standby (heating off)
[/li][li]relay contacts NO / NC: 5A (resistive load) each
[/li][li]433MHz operation
[/li][li]selectable timers per output: 0.5s, 5s, 30s, 1min, 5min, 15min, 30min and 60min
[/li][li]Heating option for use in cold environments
[/li][li]open field range of up to 30m possible
[/li][li]external antenna
[/li][li]dimensions: 80 x 70 x25mm / 3.15 x 2.75 x 0.98"
[/li][/ul][/:m]
[li]transmitter:
[ul]
[]power supply: 12V battery (included) V23GA / GP23GAC
[/li][li]dimensions: 63 x 40 x 16mm (2.5" x 1.6" x 0.6")[/li][/ul]
[/:m][/list:u]
Thanks I missed that one!
Not a problem.
I do the same thing all of the time.
Enjoy!
