I am having a problem understanding the instructions for storing additional transmitters into the memory of my VM130. Actually, the instructions are fine initially and I can store new codes (at least the Confirm LED lights up) but then I cannot use them. The instructions do not tell me how to associate a new code with either of of the 2 channels. What I really want to do though is have both channels operated by the same remote code. I use one channel on a timer mode and the other on an on/off.
Thanks for any help.
We do not quite understand.
When you learn a transmitter, it does not matter which button you press, both buttons are automatically assigned, left button to left relay, right button to right relay.
Do you have a problem configuring the relays ?
Thanks. I think you have answered my question. I want to program the individual channels but I guess I cannot. Is there a way to have the one remote button trigger both relays?
If you press both remote buttons simultaniously, both relay channels will be activated, so if you modify the remote in such a way that when you press one button the other one is also ‘pressed’, you can obtain this behaviour.
