VM129 8 relais card
Hi everybody,
I bought a VM129 preassembled kit. It appears that it isn’t as complete as the kit K8056 that contains parts to drive it through RS-232.
Can someone tell me how I can get the programmed PIC16F630 (ref on the manual: VK8056 - programmed PIC16F630 or equivalent) which is provided with the K8056 kit?
I could then improve my VM129 and drive it remotely from a computer.
Thank you in advance.
Regards,
Yvan.
Sorry, this IC is not available separately.
You could check if you can return the VM129 and get the K8056 kit or the VM118 module.
Dear moderator,
Thank you for your answer.
Unfortunately, the solution is rather expensive. I’ll buy a K8056 kit and keep my VM129 for another use.
Regards,
Yvan.
