Can the 2nd relay be turned off or can I remove it from the board? I have strict voltage requirements and need relay 2 and both LEDs not to operate. If turning off relay 2 is not an option, will removing relay 2 effect the remaining circuitry’s operation? We are exploring the possibility of seeking an exclusive usage and distribution of this product again however we have strict requirements. We only need one relay. Can Velleman produce this model with only 1 relay, thereby reducing the overall size of the circuit board? I suggest the answer is yes however you may require us to purchase a certain amount of this product.
We are looking to make a kit of: (8)- VM119(designed to the above specs), and (1) VM118R per kit. The kit is intended to sell here in the US initially with the intent to go global with sales. Who at Velleman would we need to contact to explore this possibility?
Thank you.
Jack O’Hara- Vice President
O’Hara & O’Hara, Inc.
San Antonio, TX
