VM116/K8062 on Linux
Hi ,
I’m a french student and i’m currently working on my school project.
To do this I used a velleman card (VM116/k8062) and a linux distribution ( Mint) .
But i’m have some difficulties sending data to/recognising the card…
I noticed that with commedi drivers and the uses of the vmk80xx dirver, my card is detected like a VM140. can some one help me ?
i want to made my own application in c++ with QT framework but the dll doesn’t exist with the extention " .so "
Hello @theGreatStudent
A tu minutieusement recherché sur le forum ?
N’y a t’il pas des possibilités d’utiliser une dll même sous linux surtout en c++ (enfin a condition que la dll soit un minimum compatible … sinon, wine ? mono ? …)
Bonne continuation !
Have you thoroughly researched on the forum?
Are there not possibilities to use a dll even under linux especially in c++ (well a condition that the dll is a minimum compatible … if not, wine? Mono? …)
Good continuation !
Maybe this can help you further,
K8062 For Linux (sourceforge.net)
https://github.com/tversteeg/VM116
Raspberry Pi As a DMX Light Controller : 5 Steps (with Pictures) - Instructables
Download; Protocol manual / DLL.
Software development kit
All info: USB CONTROLLED DMX INTERFACE - Whadda
Velleman Support
