When i try to program via ICSP the ProgPic2 says “No pic on board, Programmer must be set to PGM…”
I messure the votltage on VPP and GND on the ICSP connector whit SW5 in PGM mode and had only 9.5 volt, isen´t that to less?
If i put the PIC in the socket onboard of the programer there is no problems.
The incoming voltage is ok 12.24V DC.
What is wrong?
olimex.com/dev/images/PIC/PIC-P28-sch.gif
Here is the shematic of the dev board the pic is on, the DEV boards ICSP connector have 6 pins and VM111 only 5 pins, i tryed just to connent the first 5 pins, can that be the problem? The PIC only need 2 wires for ICSP or??
