VM111 dont work!?
Hi, I have a VM111 and cannot get it to run the install test.It says there is no programmer connected, it is . I have checked the connection with the serial cable twice; is there a driver or somthing that I have missed ? Ihave a 12v dc 500ma power supply and am using a emachines E4028 running XP.
The voltage connected to the programmer should be at least 15V. See thread [forum.vellemanprojects.eu/t/k8048-supply-voltage-should-be-15v/1161/1)
If it is an unregulated power supply, then most probably it’s Ok (unregulated supply tend to give more than their specified output voltage).
Perhaps this is one step closer to the solution of your problem. :smiley:
