I’m using a VM110N to connect 4 pushbuttons to the board via the digital input ports and then I capture the “Push” on a client computer for futher actions. The cable I use between the board and the buttons is a shield UTP cable where I only use 2 cables.
I now have a requirement where I need to place the button 60 meters from the board. Would the signal be strong enough to capture the push on the button?
If not what are my options?
There should not be any problems using shielded twisted pair cable.
[quote]Would the signal be strong enough to capture the push on the button?[/quote]Yes. You can connect the buttons between the digital inputs and GND terminal. There are 20k pull-up resistors on the board. No need for external power supply.
[quote]And what if its not shielded?[/quote] The purpose of shielding is canceling out electromagnetic interference (EMI) from external sources.
If the environment is not electromagnetically very “noisy”, it may be OK to use unshielded twisted pair (UTP) cable. en.wikipedia.org/wiki/Twisted_pair
