Hello
I have a problem with my VM110 interface cart which I use for inputs, to control a buzzer and to control two 12VDC relays.
I connected the relays as instructed in the manual and like I did in earlier projects. The interface cart was able to control the relay like it was supposed to be in an early test stage of the project. In a later stage, I began to experience some problems.
When I activate the output, the relay switches on like it is supposed to be. I measure 12VDC over the relay’s coil. Everything is fine so far! When I deactivate the output again, the relay does not switches off. I still measure 3 to 6V over the coil which is probably too high to make the relay switch off. The led’s on the cart are still working as they are supposed to be.
Is my VM110 broken? What can cause this problem? Any help is welcome
Thanks!
