VM110 (K8055) and VM125?
I’m learning how to use the VM110 and at this point I’m still on the practise of the basic programing and use of the dll on VB, but Im looking forward in the use of the board and I have a some questions (or I should say a LOOOOTT of questions).
[color=blue]Is possible to connect the VM125 (Ultrasonic module) to the VM110 board?[/color] I almost sure the answer is yes, but I should use the Digital Out or the Analog Out from the VM125?
Depends.
If you use the analog out of the VM125, then you need to connect it to an analog in.
If you use the digital out, you need to connect it to the… digital input of the K8055 :slight_smile:
hahaha… Ok so I can use any one whit no problem.
Now a second question: its posible to control a servomotor connected to the board digital Out?
I know how to using a basic stamp, so I guess will be the same…
You’ll find some discussion of this topic in the thread:
[forum.vellemanprojects.eu/t/controlling-servos-with-the-k8055/692/1)
