VM110 Error - connection problem
Hi
I seem to have an intermittent problem connecting to my board. This happened a few months ago but then corrected itself.
The error is:
On powering up the board the Power LED comes on and LD8 flashes three times but then stays on. I cannot connect to the board. I tried removing IC4 but still cannot connect. What error message does the above flashing sequence convey?
Saqib
In my experience LD8 staying on after the third flash means that the card was not able to connect to the computers HID driver. The exact same happens when you plug the card into a cell phone charger or a powered USB hub that isn’t connected to a computer.
You did not tell us which operating system and version you are running.
