VM110 Collector Output Max Drain per Port?
My first post so hopefully i dont get it wrong :wink:
My question is :
The 50v/100ma MAX limit on the OpenCollector Ouputs is that
Total (ex. MAX 50V/100ma / 8 outputs)
or is it MAX 50v/100ma / Output …
Like, can output 1 drain 100ma from one circut and at the same time Output 2 drains 100ma from another ?
Thanks for your time
//Kristoffer
It is: MAX 50v/100ma / Output
Indeed, even in the datasheet it is not clearly said that the specs are per output (but it is).
So you can load each output with 100mA.
[quote=“VEL255”]It is: MAX 50v/100ma / Output
So you can load each output with 100mA.[/quote]
Thank your very much!
