VM110 and mV analogue input
The input needs to be triggered by a flash slave unit (Hama Synchromat). The slave unit generates a very short pulse in between 0,035 and 0,06 V. Is the VM110 sensitive to this time and Voltage range? If not what would be the remedy? Any solution will do that reacts on an external flash.
Best regards,
Paul
It seems that this is not possible using the VM110.
The sampling interval is 10ms. If the pulse is shorter, it can’t be detected.
thx
