I want to interface to a variable-speed fan controller using the VM110. Unfortunately the fan controller requires an input that varies from 0-10vDC, while the VM110 analogue outputs vary from 0-5vDC. Is there any easy way of bridging this gap, or am I out of luck?
The supply voltage of the K8055 is +5V from the PC. There is no way to increase the analog output of the K8055 to 0-10V.
The solution is to use an external operational amplifier and an external power supply to get the 0-10V output.
[quote=“VEL255”]The supply voltage of the K8055 is +5V from the PC. There is no way to increase the analog output of the K8055 to 0-10V.
The solution is to use an external operational amplifier and an external power supply to get the 0-10V output.[/quote]
Okay, thanks. Perhaps I’ll try plan B, which is a step-up transformer (110vAC/220vAC) on the output from the fan controller
I use my VM110 to switch electric points on my model railway, using an external power block supplying the CLAMP and GND terminals.
I want to use the DAC outputs to control 12vdc motors in model trains. I am not an electronics student, just want an easily implemented solution.
I tried a ‘Sparkfun’ 1A MOSFET but ran into trouble because I ruined it with static. I don’t want a complicated circuit diagram - just something I can use very easily and very quickly. Preferably a readymade module with 2 inputs from the DAC1 or DAC2 and GND for the signal. 2 inputs from a 12vdc 1A power source and 2 outputs to the track which is 2-rail. The ‘Sparkfun’ is cheap and very compact (about the size of a postage stamp) but is complicated by the reversing and stopping arrangements which involve having to supply logic high/low inputs and a 5vdc supply which the K8055 does not have in terminal form.
