Vm109
Estimated sr. have a problem with two recipients vm 109 estan placed on the verge of garage to a distance of 100 m aprox.una of other one, a few times work well and it is necessary to place others the issuer to less of 1m in order that they are activated and both simultaneously, with 5 issuers 2 vm108 and 3 vm130t. Thank you for anticipated(advanced) by his(her,your) response.
Sorry, but we have troubles understanding your question.
Please have it translated or maybe you could post in french ?
I’ll try to translate it better. I have a problem with two vm109. They are installed on two different garage door. There are 100 meters between them. I need to approach one meter to get them both work. That happens with my 5 different emitters: 2 vm108 and 3 vm130t.
I tried one vm109 of them on a place outside the city and it works correctly.
Have you had a similar problem?
Could it be something blocking my signal?
I live on Alcalá de Guadaíra, Seville, Spain.
Thank you. I hope you can understand it now.
If it works fine at another location, there must be a source of interference present.
This will be difficult to solve. You could try relocating the antenna and/or receiver.
Did you use the same power supply when you’ve tested at a different location ?
Did you test without a load connected to the relays ?
