VM107 counter module
Sir,
How must I do to use time counter and display elapsed time as a LED count up timer.
VM107 counter module settings Dip switch positions are: 1&2: on to use mm:sec / 3:off and 4: on to use oscillator.
The Notice specify: Ideal for counting people or parts, for keeping scores, etc… The HOURS:MIN and the MIN:SEC functions are also very practical (displays 23:59 & 59:59). A built-in oscillator makes it possible to time intervals without making use of an external oscillator (clock function). Counting impulses (addition & subtraction) can be given both through push buttons and the counting inputs. A memory function constantly compares the current value with a preset value and activates an output for as long as both are equal.
Self diagnostic is good. Display mode is mm:ss. Counts are only active through on-board pushbuttons.
How to start and stop time counting?
The dealer LED electronics 6220 Fleurus is unable to give me explanations.
Thank you
JC Meunier
jcmeunier@swing.be
JCMEUNIER
Belgium
  1. Setting the DIP switches (as you did)
  2. Activate the UP input to count up the time or activeate the DOWN input to count down.
[quote=“VEL456”]1) Setting the DIP switches (as you did)
2) Activate the UP input to count up the time or activeate the DOWN input to count down.[/quote]
Thank you . All is ok
Fine module as LED Count up or Down timer displaying elapsed time.
JCM
