I am building an observatory which has a PC i remote into to control the telescope/roof open & close. i need to be able to do the following.
- Control 4 x 12v dc motors rated about 8-12amp each
 - I would like to be able to control these via PC through a SW interface (on/off)
 - I would like to be to manually control these motors through my own toggle switches for each motor (on/off/on) without the PC on (in case it ever broke while using, i need a manually way to run these motors)
 - I would like the ability to use a remote fob/controller to control the motors
 - i would like a few more ports/relays on the board so i can control more equipment (minimum 8 ports in total)
My initial thoughts were to start with this.
VM 8090 Velleman 8 Channel USB Relay Card
But i would like to use large rocker switches (make myself a separate front control panel) instead of using those little toggle buttons on the picture, is this possible?.
Can i operate this board manually with my rocker switches without a pc running (i will power it with a battery/power supply)?
Can i add remote fob/controller ability to open close the relays?.
Many thanks,
Paddy
