Good day
I’m steffen I’m from Germany and writer here on google translate
I bought the VM201, unfortunately I can not do anything because the pulses are missing and so my home relay for the light can not control,
is there a possibility that to programieren in porgramm or can I do this with an update?
hello I have also bought the set vm201. Now I’m stuck with the same problem, I also need a inpuls contact for opening / closing my gate,is this possible with programming?
best this is not really what we mean .when we press the button the relay should only give a pulse.
with this app, we still need to set a timer.[/quote]
Hello Geoffrey, did you find any solution for this problem? I have the same problem.
I’m not an electronics or relay specialist, but what about leaving the relay away and use the input for the relais to get a pluse?
Does someone kwon with relay is used? Can’t this one not be replaced by an other contactor? With same dimession
Does someone kwon with relay is used? Can’t this one not be replaced by an other contactor? With same dimession[/quote]
Hi Velleman guys,
I’m also using VM201 to generate pulses. It could be great whether you can update de Androit App to accept this way of working. My idea: At timer menu, include the possibility to indicate if a channel is going to be used as “pulse” or standard switch on /off. In case you select “pulse”, indicate the time to balance, (i.e. 1s to 1h or more).
Hopefully you can update soon
Thank you
hello All,
I’m also interested to generate pulses with the VM201 or VM204 to drive some EPN510 where the recommend pulse lenght is 50ms hager.be/produits-e-catalogu … /19923.htm
even if 1s could work, i will destroy them if I use them too much with pulse of 1sec.
as far as i can see, at this moment, it’s not possible to generate pulses around 50ms…
