Where should a ‘start’ button go on the VM188 timer board? Can it be a momentary pushbutton or does it need to be like a toggle switch?
I want to activate the timer for 30 seconds and have it shut off at the end.
What is the best way of accomplishing this?
The VM188 does not have a start button.
You might want to look at the VM141
http://www.vellemanusa.com/products/view/?id=523889
You can find the manual here.
http://www.vellemanusa.com/support/downloads/?code=VM141
Thanks, ‘Wrong Way’ - appreciate the response.
No problem.
I hope your project goes well.
