Hey,
I understand that the vm 141 can be retriggered on power ON by bridging the pushbutton. However I would like to retrigger the timer continuously while the power supply is uninterrupted. Any ideas of what is the best way to do this?
I thought of hooking up a signal relay driven by the NO relay port to the start button. This way when the timer is finished the NO port will go high and drive the signal relay and will retrigger the unit. This could work although I would like to keep things as simple as possible and so I would appreciate if I didnt have to do this. Thanks!
