Vm-137
I’d like to extend the temperature range of the VM-137 thermostat. It needs to have an upper limit of 112 F or above. How would I do this?
Instructions are printed on top of the PCB.
It will tell you what resistors to change.
Thanks for the reply. I actually did see those instructions on the board, but they seemed a little cryptic to someone like myself; a relative newbie when it comes to such stuff and I’ve had the board a long time. If there were any build instructions with the kit I’ve long since lost them and forget if that was ever pointed out. Anyway, I get it now and will see what I can do with the temperature setting. Again thanks for your reply.
If you are looking for the schematics you can download them from this link.
http://www.vellemanusa.com/downloads/0/minikits/manuals/manual_mk138.pdf
If you are looking for the users manual you can download it from this link
http://www.vellemanusa.com/downloads/0/modules/usermanual_vm137.pdf
http://www.vellemanusa.com/downloads/0/infosheets/vm137_uk.pdf
