VM-116 and DMX Lightplayer issue
I am very new to this, and am working out what to most are very simple things. I can do that. But I’ve created three fixtures in DMX player. An Elation Dimmer, A Swarm4 light fixture and a ADJ FX Fusion Bar 4, using the first 14 DMX addresses. They work, it’s controlling them well. I’ve added a Scene and have it working at start up to turn on the fixtures to warm up.
But when I add a second Scene however, and save it once (As a uniquely named show), it reopens with 12 fixtures! 4 of each with sequential DMX addresses. The Scene still works, but the labels are of course totally off.
Is this a known issue or have I walked into something? Same effect of two separate computer systems, first an Dell Studio i7 desktop with Win 7 64 bit, second an old Dell with 32 bit Vista.
Thanks,
JD
You can try the solution mentioned in this thread: viewtopic.php?f=3&t=5824
In case of 32 bit Vista, please copy the files K8062D.DLL and K8062E.EXE to the Windows subdirectory System32.
Thank you for you reply. I will try it tomorrow.
I did figure out a workaround that involved resetting the correct number of fixtures in the .SHW file using a text editor (I found the number of fixtures matched the number of channels as it saved). This allowed me to accomplish something today. I am developing the show on the Win7 system, but will used the Vista laptop to run it at events. The edited .SHW file seems to work on both but if I could just save the thing without the extra steps it will be much preferred. In either case, this is FAR better than the mechanical controller it’s replacing!
Thanks again!
[quote]I did figure out a workaround that involved resetting the correct number of fixtures in the .SHW file using a text editor (I found the number of fixtures matched the number of channels as it saved).[/quote]It’s nice you found a workaround.
This also indicates the problem is most probably related to the software “DMX-LightPlayer”.
This software is third party product from DJ Swakke.
The files K8062D.DLL and K8062E.EXE act as a ‘link’ between the DMX-LightPlayer software and the VM116 hardware via USB.
Replacing these files with the new version can not fix the problem.
