Vm 109
I bought a 2-CHANNEL RF REMOTE CONTROL SET VM 109.
Are the relay contacts for use with 220V ?
In theory yes, however, we do not recommend to run 230VAC trough the relays as this might cause interference with the receiver circuit. Use a second relay instead. Furthermore, relay contacts are not suppressed, so do not connect inductive or capacitive loads.
