I am using VM 109, but during wintertime the reach distance is very short. What can I do?
Due to the cold it is possible that the sensitivity of the receiver is reduced.
try to relocate the antenna,
Other trick is to put a 47ohm / 5W resistor inside the receiver enclosure, connected to the 12V supply. This will heat up the circuit.
