I have one head and dry to install firmware for it. Using Arduine 1.5.7 and trying to upload firmware Vertex-m1-v1-1-h1. Virtual COM Port driver release 2014-09-29. Result is fatalerror: don’t find file Configuration.h.
What is wrong?
Check in the directory where you put the firmware (where the Marlin.ino is) if there is a “configuration.h” file. If not try to extract the zip again.
You must use arduino 1.0.6. The Version you are using is still a beta version…
