Hi I am just finishing building the printer and am using the US plug and the manual only shows the colour code for the UK plug on the power supply. I’m pretty sure I have it wire properly but if someone can send me a picture of the US plug wired to the power supply it would be much appreciated.
There is a useful wiring colour table here:
http://www.allaboutcircuits.com/textbook/reference/chpt-2/wiring-color-codes-infographic/
In the UK & Europe, Brown is live, Blue is Neutral and Green / Yellow is Earth.
In the USA typically Black is Live, White is Neutral and Green (Or Green/Yellow) is earth. Remember to change the voltage slide switch on your power supply to 110v first and if in doubt, ask a local electrician if you’re not too sure.
