Vertex K8400 with Repetier 1.0.6 and Curaengine problem
I just bought Vertex K4800. Using Repetier 1.0.6. Slicing with Slick3r and Curaengine works. But Vertex K8400 start only when sliced with Slick3r. According to the instructions, the Curaengine is the right choice. What to do? I have used Windows XP and Windows 7. I have tried with SD-card. I have tried with the firmware vertex-m1-v1-h1 and v1.1.
Are you sure that the display says for the heated bed: 0°/0°?
If their is standing 0°/50° then the printer is waiting until the bed reaches 50° but there isn’t a heated bed…
And did you change anything in the Cura engine settings in the VERTEX Repetier?
Cheers,
Dylan
[quote=“minitreintje”]Are you sure that the display says for the heated bed: 0°/0°?
Cheers,
Dylan[/quote]
I found the reason. I had downloaded the Repetier software from Repetier website. I downloaded now from Velleman website and now all is fine.
I had the same problem… Velleman sets the settings of the heated bed in Repetier to 0 while the original Repetier sets the heated bed at 50 degrees.
cheers,
Dylan
