Apologies for a long post, but this is a serious problem. Edited: Maybe this should be in Printing issues forum. Sorry if wrongly posted.
Had a few phone calls with my supplier today and this seems a very strange problem that they haven’t seen before.
Am attaching this dropbox URL for a photo, showing the problem:
dl.dropboxusercontent.com/u/739 … .26.11.jpg
I’ve spent the entire day, trying to figure out, why the Vertex K8400 all of a sudden can’t print round shapes anymore. Wether from the Repetier software or from the SD card, all results are the same - round shapes are utterly impossible to print now.
Here is a description of events:
- Some 2 or 3 weeks ago (?), I bought the printer.
- Built it in a week, during the evening.
- Hooked it up to my Windows 7 desktop pc - worked like a charm, perfect.
During last week, I even printed a thread nipple (1/2" BSPT on 1 side, M20x1.5 on the other): it’s the red object on the photo. The M20x1.5 fits straight from the printer into the couterparts’s thread needed, no problem - very good print.
Thursday: Windows 10 installs.
Saterday morning:
[ul]Print something, which starts out just fine. Need to stop (= stop command in Repetier), as I forgot to activate “support” in the Slicer & I’d need that for this print.
Restart the print, now with support.
Shortly after the start, I pop down to get some coffee - during this apparently, the print stops.
Windows has a message that Repetier has stopped working & that it had installed some updates.
(I checked the updates: it was a driver update for the Nvidia Geforce GTX650 graphics card and an definition update for Windows Defender - apparently, nothing that would affect the printer).
[/ul]
After this event … the printer is unable to re-produce any round shape. Even not some it did produce earlier.
On the photo:
[ul]Upper-left - the threaded nipple, as described.
Lower left - a washer, I printed for the nipple.
Mid left - same washer, printed now… Not even remotely the same.
Lower mid - the print I started with this morning, the Z-axis bearing support, which I had to stop due to missing support.
Upper right - a later version of the same print (I had now added a radius, to save material & time): by then I had already tried several times, but decided to let this one to proceed for a bit, to see where it would go.
Mid center - same print as the original Z-axis, went back to the original file from Thingiverse. But the error is constant.
[/ul]
On this second photo, is the red nipple, as it comes out of the printer NOW (via SD Card), using the G-Code of the original one that’s next to it:
dl.dropboxusercontent.com/u/739 … .25.38.jpg
This is that G-code file:
dl.dropboxusercontent.com/u/739 … ported.gco
No matter what I try, it is not possible for the Vertex K8400 to print rounds shapes anymore.
In order to resolve this, I have tried following:
- Set Repetier to Windows 7 compatibility
- Run as Administrator
==> No result
Uninstall Repetier & re-install. I noticed that the embedded drivers could not be re-installed, as the ones on the system were “equal or newer”.
==> No result
Print off the SD card, without the K8400 being connected to the PC
==> No result.
Print off the SD card, using G-code files of the period that the printer was working correctly.
==> No result.
I’ve checked the drive pulley’s, for play
==> No play, all firm on their respective axis & motor shafts.
The belts are correctly tightened and have no play.
This is a picture, showing the firmware version:
dl.dropboxusercontent.com/u/739 … .30.45.jpg
But as this printer was sold mid July, I would assume it has the most recent firmware - as the last update to that on the forum is of last year.
I hope we can solve this issue swiftly, as the situation is rather disappointing.
Taking all above into account, I don’t think that it is a Windows 10 upgrade problem. Then the original G-code from last week - that produced a perfectly usable M20x1.5 thread at the time - would have printed correctly from the SD Card.
And it didn’t. It had the same error.
I’d have to conclude, that the problem is in the printer. Spontaniously - without any reason that I am able to identify.
Again, hope that this is picked up soon.
I have made a support ticket - but the page didn’t give me a ticket number.
And also for the second ticket, no ticket number…? I have the screenshot, but no number on it…?
Thanks,
Harry D.
