Vertex k8400 loading after every layer
Sometimes when i am printing an object it loads after every single layer. This takes a lot of extra time and rest plastic stuck to my object.
Is there a way to fix this?
Here is a movie of the problem:
[color=#4000FF]https://vimeo.com/154306739
[/color]
You should really post this in the Vertex section
You can turn this off however what it is doing is letting the previous layer cool before starting the next layer.
I also noticed the fans not running.
They are very important without them the isolater guide could clog.
If you are printing with PLA 190C is a good starting point.
You may also want to change the retraction to 4mm retraction speed to 110mm in the Cura settings
Really great job dude.
