i am running the VERTEX DELTA with the downloaded Vertex Delta Repetier V2.0.5 host. When I connect the printer by USB (seriell connection) i can work well.
I have then installed the included repetier server and connect the above host to the server. The printer is connected to the server by USB and I configured the printer with the setup wizard.
I am not able to do any print job nor I can manual move the VERTEX Delta.
What has to be the configuration for the VERTEX DELTA within the repetier server that I can run the system in the same way as if the repetier host is directly connected to the 3D-printer by USB.
Thanks you in advance for help.
Best regards
Emilleopold
