Vertex 3d printer
I have the problem that both heatsensors apear to not work.
The Main Page shows
Temp(Thermometer Symbol): 0/0° Temp(Thermometer Symbol):25/0°
H(Symbol): 0/0° Z000.00
FR(Symbol): 99% SD—%
ERR:Mintemp
The resistance of the themperture sensors are 6,4k and 6.8k at room temperture.
Can anybodey help me with my problem?
Please post your problem in a the correct sub forum
I’ve moved your topic to the correct section.
It seems like the left one isn’t connected correctly.
Check if the cable is working properly, measure the resistance of the same wire from printhead to the motherboard.
The right one is indication 25degrees so that’s good.
