With my Windows 10 system I am unable to see any of the pictures in the manual, which makes the manual useless.
Since I am unable to access the pictures, this statement may not be accurate, but it seems to me that the manual is completely torn up into stand alone sections and not contiguous in any way.
Why is the manual not available in .pdf format to avoid all of those issues?
Please help, since I cannot start assembly unless these issues are solved for me.
[quote=“kmeyer5063”]Why is the manual not available in .pdf format to avoid all of those issues?[/quote]Never tried with Windows 10 but at the end of each page there’s an “Export to PDF” option. You could try and use this.
If you are using Explorer you should consider using FireFox.
For some reason IE has been having issues for awhile now.
There should also be an “Export to PDF” button at the bottom of each chapter.
