Do you have any errors on the LCD screen like
Min temp error or Max temp error?
Do have the second print head on it?
If not you need to change the firmware.
The stock firmware is set for 2 heads.
With out the second print head (K8402)
You will get Min temp errors because it is expecting to get a reading from the 2 print head.
[quote=“Wrong Way”]Do you have any errors on the LCD screen like
You will get Min temp errors because it is expecting to get a reading from the 2 print head.[/quote]
PINDO ITALY-
on LCD error: MINTEMP
NO SECOND 3 HEAD) can’t MODIFY FIRMWARE with WINDOVS
Thanks for the instructions
I’ve replaced the firmware using the 1-head one and everything is ok!
But using the new firmware (1-head) there’s a new problem: nozzle head detaches from the insulator because the temperature has loose Threading.
The temperature has risen because: failing to rise the temperature of head, I reduced fan speed to 40%.
It’s hard to understand what you are saying
but it sounds like the thermistor is not correctly positioned
You will need to contact one of the Velleman distributors and ask if they will order it for you
