I have a new attached printer Vertex 3D printer (K8400). At first start Auto Home feature was good. After a few starts only Y- and Z-axis moves to the starting point after Auto Home enabled. X-axis makes a small movement just as it were already at the starting point. I have checked all the connections and the diode in the End-stop connector lights up.
What is the error?
Can you move the print head by hand?
If not look at this link.
http://www.k8xxx-3dprinters.crimed.be/w/index.php?title=XY-Carriage_Alignment
Try swapping the end stop to a different location to see if the problem moves with it.
[quote=“Wrong Way”]Can you move the print head by hand?
Try swapping the end stop to a different location to see if the problem moves with it.[/quote]
Thanks!
Problem solved!
A drop of oil on the y-axis end-stop-connector caused the problem. After cleaning the connector Auto Home works as it should!
Oops,
I meant to put that out there as well.
Glad to hear it’s working.
Enjoy!
