I purchased a Velleman VM206 kit which I would like to connect to a 12 V DC solenoid valve. The idea is to open/close the valve according to how the timer has been programmed.
How should I connect the valve to the timer?
The timer module itself seems to work fine, i.e. the relay switches between on/off. The solenoid valve is rated at 12 V DC, and works when connected directly to the power source, but I can’t figure out how I should connect it to the timer.
