I am proposing to run 5W COB lights from each channel of the VM120 Light Effect Generator Mod for a one off project, limiting the current to the specified 400mA, using resistors between the channel output and the COB. The 12v COB requires a forward voltage of about 9volts, which will be provided by a total series impedance/resistance of about 7.5 ohms, 1.2W at a controller current of 400mA. Can you advise the channel output impedance so I can determine what additional resistance is required? Alternatively can you advise the output voltage at no load and the output voltage full load (400mA) so that I can calculate the impedance?
One other thing, can you advise the minimum input voltage for the controller - I’m looking at battery specifications and at a battery rating of 8Ah the voltage drops to 10-11V at 4A discharge current? I presume the output voltage would be in proportion to this input voltage?
