Velleman VM111
Hi
I am having all sorts of problems with my Velleman VM111 Pic Programmer.
I have used a usb to serial port connector and have been successful in reading my pic chip. Although I was not able to write with this. I then saw that the manual says that it is not compatible with this type of connector.
I then installed a piece of hardware to my PC which is a 2 port Native PCI Express RS232 Serial Card with 16550 UART. It now cannot detect that a pic controller is connected to the PC.
I am using PicProg 2009 software.
I am using Windows 7 (Is this compatible?)
I am using a 12v Unregulated
Can you suggest any reasons why I cannot get this to work??
Hello, Eddy12345 !
In the PICPROG 2009 hardware settings, it’s important to select VM 111/ K 8048 and
the correct COM-port number , that you are actually connected to.
