Velleman Special Connectors
God morning,
I´ve bought a Velleman VM145 (Digital panel thermometer) and would like to extend the cable for the sensor.
Concerning the card-to-cable connectors:
On card: 2pin male DC connection, 4pin male sensor connection.
Supplied: 20cm cable with mounted 2pin female and 20cm and 20cm cable with mounted 4pin connector.
What is the standard, product brand, of these connectors? Special Velleman?
I would like to buy the proper connectors so that I can extend the cables.
Best Regards
They are standard pitch 2.54mm 2-pole and 4-pole Molex-compatible connectors.
Please note that the max. distance between readout and sensor is 10m.
Good morning,
Ok! Thanks for your fast reply!
/Jan
