Velleman PCSGU250
Is it possible to generate one waveform amplitude modulated by another using the custom waveform generating library? I want to be a be able to generate audio frequency (0.1-10000 Hz) sine or square waves and then modulate their amplitude using a different wave form. Also is it possible to generate a pulse output with variable width rather than a square wave?
If not possible with the issued library is it possible to create the waveform in other software and import to the library? And if so which third party software would you use?
This is possible using the library waveform only. Please see rect1.lib file as an example.
Yes, you can create the waveform using a spreadsheet e.g. Excel.
Then copy and paste the data to the Wave Editor.
