Hi, we just assembled the Velleman Vertex k8400 with dual heads, but we have come to an issue with our slicer configuration.
The Vertex 3D Printer Repetier-Host uses both Cura and Slic3r engines to slice the STL parts, but we wish to use standalone Cura Slicer so we could use it with various operating systems with the latest update versions; doing it with Cura would be the rational choice.
The Repetier allows expoting settings, but these settings are not directly compatible with Cura and painstaking hours of work with possible 3D printer damage are needed to translate these.
Is it possible to obtain official Cura engine settings for the Dual Head printer without the Repetier-Host?
If not, has anybody already done this painstaking task?
Kind Regards
Second that.
Who uses “desktop software” Repetier in the times of Rasperry Pi, Octoprint, Cura engine inside Rpi and above all - cross platform solutions, comfortable (W)LAN mobility across studio, and “print from your smartphone via webrowser in year 2015™”?
Dual head Vertex K8400 here (printing both with 1 and 2 nozzles). We need to feed in cura ini into barebone cura engine. It can be done - line by line looking what are the vertex single and dual head suggested values by the manufacturer (you - Velleman) in Repetier Cura… through GUI. Because, as mentioned above, the export from Repetier seems to f* things up/not work at all when trying to use exported file (even with cleanup).
Guys from Velleman - could you please share Cura engine ini for K8400 single / dual? IMHO, for you it would be a “quick task” as you know product/settings by heart and sharing this a) would be a nice support for the users of your product and b) would save us time/confussion. Win/win?
[profile]
layer_height = 0.1
wall_thickness = 0.7
retraction_enable = True
solid_layer_thickness = 0.3
fill_density = 100
nozzle_size = 0.35
print_speed = 50
print_temperature = 205
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 0
support = None
platform_adhesion = None
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 1.75
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 70
retraction_speed = 40.0
retraction_amount = 4.5
retraction_dual_amount = 16.5
retraction_min_travel = 0.1
retraction_combing = All
retraction_minimal_extrusion = 0.02
retraction_hop = 0.0
bottom_thickness = 0.3
layer0_width_factor = 100
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 80
bottom_layer_speed = 20
infill_speed = 0.0
solidarea_speed = 0.0
inset0_speed = 0.0
insetx_speed = 0.0
cool_min_layer_time = 5
fan_enabled = True
skirt_line_count = 3
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 0.5
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 0
cool_head_lift = True
solid_top = True
solid_bottom = True
fill_overlap = 0
support_type = Grid
support_angle = 5
support_fill_rate = 20
support_xy_distance = 0.8
support_z_distance = 0.1
spiralize = False
simple_mode = False
brim_line_count = 20
raft_margin = 5.0
raft_line_spacing = 1
raft_base_thickness = 0.3
raft_base_linewidth = 0.7
raft_interface_thickness = 0.2
raft_interface_linewidth = 0.2
raft_airgap_all = 0.0
raft_airgap = 0.0
raft_surface_layers = 2
raft_surface_thickness = 0.2
raft_surface_linewidth = 0.2
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config =
object_center_x = -1
object_center_y = -1
[alterations]
start.gcode = G28
G1 Z5 F10
G1 Z0 F10
M106 S165 ; Turn on fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
; Activate all used extruder
M104 T1 S{print_temperature}
G92 E0 ; Reset extruder position
; Wait for all used extruders to reach temperature
M109 T1 S{print_temperature}
T1
M83
G1 E10 F100
M82
M117 Vertex is printing
G1 F1000 Z5
end.gcode = M107
; Disable all extruder
G91 ; Relative positioning
T1
G1 E-1 ; Reduce filament pressure
M104 T1 S0
M140 S0 ; Disable heated bed
M84 ; Turn steppers off
T1
start2.gcode = ;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M104 S{print_temperature} ;Uncomment to add your own temperature line
;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
T1 ;Switch to the 2nd extruder
G92 E0 ;zero the extruded length
G1 F200 E10 ;extrude 10mm of feed stock
G92 E0 ;zero the extruded length again
G1 F200 E-{retraction_dual_amount}
T0 ;Switch to the first extruder
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
end2.gcode = ;End GCode
M104 T0 S0 ;extruder heater off
M104 T1 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
;{profile_string}
start3.gcode = ;Sliced at: {day} {date} {time}
G21 ;metric values
T2 ;Switch to the 2nd extruder
G1 F{travel_speed}
M117 Printing...
end3.gcode = ;End GCode
M104 T2 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
start4.gcode = ;Sliced at: {day} {date} {time}
;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
G21 ;metric values
T3 ;Switch to the 4th extruder
T2 ;Switch to the 3th extruder
G1 F{travel_speed}
M117 Printing...
end4.gcode = ;End GCode
M104 T3 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added after the T(n)
DUAL.ini
[profile]
layer_height = 0.1
wall_thickness = 0.8
solid_layer_thickness = 0.6
fill_density = 20
nozzle_size = 0.35
print_speed = 50
print_temperature = 190
print_temperature2 = 200
print_bed_temperature = 70
support = None
wipe_tower = False
ooze_shield = False
filament_diameter2 = 1.75
filament_flow = 70
retraction_min_travel = 1.5
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 80
infill_speed = 0.0
inset0_speed = 0.0
insetx_speed = 0.0
fan_enabled = True
skirt_line_count = 1
skirt_gap = 3.0
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 10
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
support_type = Lines
support_angle = 60
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = 0.15
spiralize = False
simple_mode = False
raft_margin = 5.0
raft_line_spacing = 3.0
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap = 0.22
raft_surface_thickness = 0.27
raft_surface_linewidth = 0.4
plugin_config =
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
M82 ;set extruder to absolute mode
G1 F200 E5 ;extrude 5mm of feed stock
G1 F{travel_speed}
M117 Printing...
end.gcode = ;End GCode
M104 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
G21 ;metric values
G1 F200 E20 ;extrude 20mm of feed stock
G1 F{travel_speed}
M117 Printing...
M84 ;steppers off
;{profile_string}
G21 ;metric values
G1 F{travel_speed}
M117 Printing...
M84 ;steppers off
;{profile_string}
G21 ;metric values
G1 F{travel_speed}
M117 Printing...
M84 ;steppers off
;{profile_string}
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
hi all,
in my care settings 15.04 there is something wrong, because after the gcode generated and copied to the memory … printing does not start but the vertex makes a strange noise.
Do you have any suggestions?
PS
In the section “Print Head size” all settings are “0”
NOTE
Missing some settings, for example reversing the z-axis (on repeater host is present)
The start.gcode and end.gcode in the SINGLE.ini file above may cause some issues. I replaced every occasion of T1 with T0 (in start.gcode and end.gcode) and that made it possible to print without the second print head heating up etc.
